Aluminum Machining of Structural Aerospace Parts Improves with Makino A-Series 5-Axis HMCs
Mason, OH – August 29, 2012 – Makino announces its new A-Series 5-axis horizontal machining centers for high-speed, high-efficiency aluminum machining of large, thin aerospace structural components, including wing spars, wing panels and floor beams. This new family of aluminum machining centers includes the A4, A8, A12 and A20, each positioned for specific part lengths ranging from 4 meters to 20 meters.
“Makino’s MAG-Series established the company as a leader in aerospace aluminum machining technologies, and since its release, we’ve continued to improve and expand upon our capabilities,” said David Ward, Makino horizontal product line manager. “With the A-Series, we’ve focused on maximizing the average metal-removal rate throughout the machine process, improving spindle capabilities for heavy roughing, and optimizing linear and radial axis acceleration for pocketing and wall finishing. The result is a fast, highly accurate, highly predictable, 5-axis aluminum machining center.”
A-Series machines come standardly equipped with a 33,000-rpm HSK-F80 spindle featuring a high-power output of 107 hp (80 kW). At peak power, the A-Series spindle can produce chip-removal rates up to 5,600 cm3/min (300 in3/min). Workpiece accessibility, size and weight specifications for the A-Series machines are as follows:
  X-, Y-, Z-Axis Travels Maximum Workpiece Maximum Weight
A4 4,200 x 2,200 x 650 mm 4,000 x 2,200 x 500 mm 3,750 kg
A8 8,200 x 2,200 x 650 mm 8,000 x 2,200 x 500 mm 5,000 kg
A12 12,200 x 2,200 x 650 mm 12,000 x 2,200 x 500 mm 7,000 kg
A20 20,200 x 2,200 x 650 mm 20,000 x 2,200 x 500 mm 10,500 kg
Improved Accuracy and Accessibility
Supporting the powerful A-Series spindle is a compact, fully integrated A and C axis design.  With plus or minus 110 degrees of tilt in the A-axis and an infinite degree of rotation in the C-axis, this spindle and head design provides 5-axis roughing and finishing capabilities and ideal part accessibility for deep pockets and side walls.
All A-Series machines share a common FEA column design to reduce weight while maintaining rigidity. Movement of the column along the X-axis is powered by eight linear motors with 0.8G acceleration. An extra-wide column base and dual-supported ball screws in the Y-axis ensure stability of the column and spindle during rapid axis movement.
Also featured in the A-Series is Makino’s Volumetric Accuracy Compensation technology for improved tool-tip positioning accuracy. This technology provides in-process tool-tip corrections for sustained dynamic accuracy even in complex three-dimensional geometries.
Advanced Optional Spindle Technology
The A-Series can also be equipped with an optional 120 kW spindle. This spindle maintains the same maximum rpm of 33,000 but delivers 50 percent more power, enabling increased metal-removal roughing rates to as much as 6,550 cm3/min (400 in3/min) in aerospace-grade aluminum.
Complementing the additional power, this spindle also provides through-spindle coolant capability, a first for the MAG-Series spindle design. With a through-spindle coolant pressure of 1.5 MPa, or 217 psi, this capability is extremely beneficial for chip evacuation during pocketing and reducing pecking requirements for improved drilling efficiency. Manufacturers also benefit from extended tool life as a result of direct tool cooling and added cutting lubricity.
The A-Series has an advanced spindle that also features Makino’s third generation of Autonomic Spindle Technology (AST3). With AST3, the spindle uses displacement sensors to monitor forces against the spindle. During machining, the data from these sensors is evaluated in real time. If an unsafe load condition is detected, the AST3 reduces the feedrate to prevent damage to the spindle and tooling.
A world leader in advanced CNC machining centers, Makino is committed to providing high-performance, leading-edge machining technologies and innovative engineered process solutions that enable manufacturers to focus on making what matters. Makino offers a wide range of high-precision metal-cutting and EDM machinery, including horizontal machining centers,  vertical machining centers,  5-axis machining centers,  graphite machining centers, and wire and Ram EDMs. Makino’s flexible automation solutions provide reduced labor costs and increased throughput in a variety of production volumes and designs. Makino’s engineering services offers industry-leading expertise for even the most challenging applications across all industries. For more information, call 1-800-552-3288 or visit
A20: JPG
For more information, additional images and releases, visit Connect with Makino on Facebook at Follow Makino on Twitter at
