Horizontal Machining Center Productivity Improved with Makino’s Inertia Active Control Technology
Makino’s new Inertia Active Control technology optimizes B-axis rotation for reduced non-cut time
Mason, OH – February 2012 – Makino announces its new horizontal machining center technology, Inertia Active Control (IAC), for improved productivity through direct-drive rotary table optimization. By effectively reducing non-cut times resulting from table rotation, IAC technology gives manufacturers improved efficiency and profitability.
“Every second of non-cut time that can be eliminated from the machining process provides manufacturers with a step above the competition,” says David Ward, Makino’s horizontal product line manager. “IAC technology provides that advantage by evaluating and optimizing the acceleration and deceleration settings on a per-pallet basis. For a production manufacturer, this could mean thousands of additional parts produced on each horizontal machining center over a year’s time.”
The foundation for IAC technology lies in Makino’s direct-drive (DD) rotary table design that provides inertia feedback from the B-axis motor to the machining center’s control system. While acceleration and deceleration rates for standard rotary tables are typically set for maximum inertia and weight to ensure accuracy, IAC uses data from the DD rotary table to quickly evaluate and adjust acceleration and deceleration settings to optimal levels for the specific pallet condition.
IAC technology is currently available on Makino’s nx line of horizontal machining centers, the a51nx and a61nx. These 40-taper machining centers extend the capabilities of the highly successful a-series with a host of technologies for next-generation productivity, accuracy and reliability. The a51nx and a61nx feature pallet sizes of 400mm and 500mm, respectively.
To find out more about IAC and other new control technologies from Makino, visit www.makino.com/events and register for the “New Control Technologies” webinar series.
Direct-Drive Rotary Table
Makino’s DD rotary table offers high-speed positioning capability while reducing B-axis complexity and eliminating backlash, caused by wear. Included in the table’s design are cooling jackets that remove heat from the motor and table bearings assuring sustained dynamic accuracy. Its fully programmable axis with 0.0001-degree resolution enables full four-axis contouring capability for complex part geometries.
A world leader in advanced CNC machining centers, Makino provides a wide range of high-precision metal-cutting and EDM machinery, including horizontal machining centersvertical machining centers5-axis machining centersgraphite machining centers, and wire and Ram EDMs. Our flexible automation solutions provide reduced labor costs and increased throughput in a variety of production volumes and designs. With Makino engineering services, we offer industry-leading expertise for even the most challenging applications across all industries. For more information, call 1-800-552-3288 or visit makino.com.
IAC Technology YouTube Video
Visit www.makino.com/media for releases, images and other media information.
Makino logo: JPG
Want to embed a Makino video on your website for free? The process is quick and easy. Simply visit Makino's YouTube channel (www.youtube.com/user/MakinoMachineTools) and find dozens of videos. Under the video's description you'll find a “Share” button which will provide the embed HTML code. Copy and paste this code into the HTML of your desired webpage. It's a simple and free way to add rich-media to your website. If you have any questions or would like additional help, feel free to e-mail makino@gyro.com
