V56 Drives Out Costs by Virtually Eliminating Polishing
Vertical machining center is suitable for machining small- to medium-size applications
MASON, OH—April, 2006— The Makino V56 vertical machining center is ideal for machining plastic molds and die cast dies for automotive parts, as well as components of home appliances, office automation equipment and IT-related products.
Built with many of the same high-performance capabilities as the V33 and V77, the V56 can also machine the dies for precision press dies and the mold base of plastic molds and forging dies, and virtually eliminate the need to polish small- and medium-size dies/molds.
V56 Benefits and Features
The V56 can handle payloads weighing up to 1,760 pounds (800 kg) on a 41.3- x 21.7-inch (1,050 x 550 mm) table. There are no overhangs along the X-,Y-, Z-axis travel of 35.4 x 21.7 x 17.7 inches (900 x 550 x 450 mm), enabling the V56 to provide high-stiffness and rigidity, therefore high-accuracy machining along its entire axes.
While the V56 maintains a relatively compact footprint of 98 x 96 x 108 inches (2,500 x 2,450 x 2,750 mm), it possesses a large machining capacity. The V56 can accommodate workpieces as large as 41.3 x 28.3 x 17.7 inches (1,050 x 720 x 450 mm) and vices that extend over the table. In addition, the table is a comfortable 33.5 inches (850 mm) above the floor, offering operators easy accessibility to perform setups. The front of the machine also offers operators exceptional accessibility to the workpiece and spindle to check machined surfaces and tool condition.
The V56 utilizes a 40-taper, 20,000-rpm spindle, with patented spindle core cooling and under-race lubrication system. This system prevents spindle thermal distortion even during the longest applications, and reduces vibration at high operating speeds, resulting in longer tool life and superior surface finishes.  Makino’s V56 has rapid traverse and maximum cutting feed rates of 800 inches/min (20,000 mm/min).
A high-performance 0.000002-inch (0.00005-mm) scale feedback system is available to provide exceptionally smooth machined surfaces even in high-feedrate machining of 3-D shapes involving continuous tiny blocks of NC data. Advanced data management technology and Makino’s proprietary, next generation Super Geometric Intelligence servo control deliver the lowest cycle times available. This technology maintains exceptional accuracy and produces quality finishes that only a machine designed specifically for a die/mold application can provide.
Insulation is applied under the bed and around the bed and column to prevent the ambient air temperature from causing machine attitude changes that deteriorate machining accuracy. A thermal stability system that works to provide high-accuracy is also available as an optional specification to stabilize the column temperature by continuously circulating a special fluid through the column.
A six-nozzle coolant supply device, an air blower and through-spindle air reliably flush chips through outlets underneath the table onto two high-speed conveyors for quick removal from the machine.
V56 Images: JPG TIF
